Undefined reference to rtems_bsdnet_config
Sudheesh J
sudheesh at atinav.com
Fri Nov 1 07:55:57 UTC 2002
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
To: "Sudheesh J" <sudheesh at atinav.com>
Cc: <rtems-users at oarcorp.com>
Sent: Thursday, October 31, 2002 10:14 AM
Subject: Re: Undefined reference to rtems_bsdnet_config
> > Sudheesh J wrote:
> > Hi,
> > Sorry for bugging you again. While trying to build a simple
> > networking app, an undefined reference to rtems_bsdnet_config was
> > produced.
> That's the network configuration file and it is up to you to define
> that structure. See the networkconfig.h file in the top directory
> of the network demos.
Thank you, once again. I had read
http://www.rtems.com/rtems/maillistArchives/rtems-users/2000/august/msg00028
.html. But I thought it had something related to my target architecture.
> > I'm using m68k bsk efi332.
> This BSP doesn't have a NIC driver. Do you have a NIC on your 332
> board?
Well, no, for the time being. I've just tried a target BSP.
> SOunds like you need a driver.
> It is possible to use the loopback interface but that won't connect
> you to another system.
The loopback interface should suffice, at least for now.
> > thank you for any help.
> > Sudheesh
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
