Excimer BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Nov 1 21:38:58 UTC 2002
Steven Grunza wrote:
> I'm working on a new BSP for the Motorola Excimer board. One problem I've
> run into is the start.o file not being copied to the excimer/lib
> directory. I build the ppcn_60x and psim BSP's and their copies of start.o
> ended up in their respective {prefix-dir}/powerpc-rtems/{BSP name}/lib
> directory but somehow my Makefile's don't do it.
> Does anyone know what makefile is responsible for moving the start.o file
> to the lib directory?
libbsp/CPU/BSP/start/Makefile.am
Please use one of the "new exception model" BSPs as your baseline.
So something like motorola_shared would be a better model for the
interrupt processing. Adding another "old exception processing" model
BSP just means that eventually there is another BSP to convert when
that model finally goes away. Sorry.
> "Unix is user friendly, it's just | Steven Grunza
> particular about with whom it | voice: (856) 787 - 2759
> makes friends." | fax: (856) 866 - 2033
> - Unknown | mailto:steven_grunza at ieee.org
joel at OARcorp.com On-Line Applications Research
