new snapshot (ss-20021118), etc
Stephen Holford SHolford at WESCAM.com
Mon Nov 18 21:21:21 UTC 2002
Hi
As with the 20021111 snapshot, I get the following non-fatal configure
errors with the 20021118 snapshot. I'm running redhat 7.1 with the
latest autoconf (2.52) and automake (1.62) from the OAR site. The build
process completes in spite of the errors. The 20021007 snapshot does not
exhibit this behaviour.
I used the following command line:
  $ /home/rtems/tools/rtems-ss-20021118/configure --prefix=/opt/rtems
--target=powerpc-rtems --disable-networking --disable-posix
--disable-docs --disable-itron --disable-tests
--enable-bare-cpu-cflags=-mcpu=603e -mstrict-align -Dmpc8260
-DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF
--enable-bare-cpu-model=mpc8260 --enable-maintainer-mode
--enable-rtemsbsp=bare
Some of the captured output:
checking for gmake... gmake
checking for RTEMS Version... ss-20021118
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... powerpc-unknown-rtems
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for mawk... mawk
checking whether gmake sets ${MAKE}... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking if the test suites are enabled? ... no
/home/rtems/tools/rtems-ss-20021118/configure: eval: line 1: unexpected
EOF while looking for matching `''
/home/rtems/tools/rtems-ss-20021118/configure: eval: line 2: syntax
error: unexpected end of file
configure: creating ./config.status
configure: configuring in ./tools/update
Steve Holford
