new snapshot (ss-20021118), etc
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Nov 20 16:37:22 UTC 2002
Am Mit, 2002-11-20 um 16.15 schrieb Jerry Needell:
> Joel Sherrill wrote:
> > Finally there were some problems with the Makefiles in the
> > example programs so there is a new set of examples. The
> > two C++ examples appear to have obsolete C++ in them. If
> > someone C++ knowledgeable could look into those, it would
> > be appreciated.
> the examples filerdback and repeated_opens include a header file
> memory.h. This file does not appear to exist on my sparc/erc32 build.
Memory.h is a BSD-ism. It should not be used in any POSIX-compliant
code.
=> Try again with the #include <memory.h> lines removed.
If the examples still do not compile try replacing the
#include <memory.h>
lines with
(memory.h's POSIX counterpart)
> I have not delved too far into this.
RTEMS installs memory.h is if the BSD-networking stack is enabled.
Ralf
