new snapshot (ss-20021118), etc
Jerry Needell jerry.needell at unh.edu
Wed Nov 20 17:05:23 UTC 2002
Ralf Corsepius wrote:
> Am Mit, 2002-11-20 um 16.15 schrieb Jerry Needell:
>>Joel Sherrill wrote:
>>>Finally there were some problems with the Makefiles in the
>>>example programs so there is a new set of examples.  The
>>>two C++ examples appear to have obsolete C++ in them.  If
>>>someone C++ knowledgeable could look into those, it would
>>>be appreciated.
>>the examples filerdback and repeated_opens include a header file
>>memory.h. This file does not appear to exist on my sparc/erc32 build.
> Memory.h is a BSD-ism. It should not be used in any POSIX-compliant
> code.
> => Try again with the #include <memory.h> lines removed.
They do compile with this line removed - thanks.
>>I have not delved too far into this.
> RTEMS installs memory.h is if the BSD-networking stack is enabled.
OK - I do not have networking enabled.
> Ralf
_______________________________________________________________________
Jerry Needell                     | Internet: jerry.needell at unh.edu
Space Science Center/Morse Hall   | Voice: (603) 862 2732
University Of New Hampshire       | FAX:   (603) 862 0311
Durham, NH 03824                  |
