arm-rtems-gcc...no
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Nov 21 14:00:49 UTC 2002
> Sorry if I interpret you incorrectly. You said mere gcc-3.2.targ.gz. And the error messages also indicate the same. You have to apply the RTEMS patch. Or you
> have to export the cross compiler path to the PATH environment variable. The other tools also should be patched. It says arm-rtems-gcc not found.. not gcc.
> Refer the fileTOOLVERSIONS in the same ftp directory as the source archive. Then compile them for the target processor(arm).
> Or you may use the patched
> tools available at ftp://ftp.oarcorp.com/pub/rtems/releases/4.5.0/c_tools
Dead on the money until here. Always try to use the tool versions and
patches that go with a particular RTEMS version. In particular,
gcc and newlib are co-dependent with RTEMS since they must agree
on header files, cpp predefines, threading support, etc.
It is possible that a particular gcc/newlib version will work with
a range of RTEMS versions but it is better to stick with the recommended
versions. For example after 4.5, a large .h file reorg was performed
which resulted in the 4.5.0 tools not being useable with snapshots
at a certain point. More recently, we merged some BSD-isms into
newlib to clean up some more and even more recently, the signal.h
file changed in newlib and RTEMS has to stay in sync with that.
joel at OARcorp.com On-Line Applications Research
