Beginner Questions
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Nov 27 16:34:35 UTC 2002
Arun Govind wrote:
> Thanks for the quick reply. I just want to familiarize myself with the RTEMS development environment first. For that I plan to buy a board that has full compatibility. I know tis' better to learn how to resolve incompatibilities, but at least I think if not every, some beginner would face the same question and that's why I posted this question.
Cheaper and just as effective for learning purposes is to use one of the
BSPs
that is for a simulator included in gdb. I recommend the mips/jmr3904,
sparc/erc32, or powerpc/psim. At the application level, all of these
BSPs are capable of console IO, clock based services, and local loopback
support for networking. If you played some, I suspect that you could
get
more functionality from at least psim. The gdb RPMS provided include
these
simulators prebuilt.
> thank you for all your response
> Arun
> On Wed, 27 Nov 2002 08:41:04
> Joel Sherrill wrote:
> >Arun Govind wrote:
> >> I've heard that RTEMS BSP contains all the needed drivers for a particular board. And the mailing list contains a number of queries regarding driver related issues on particular boards. Again as a beginner, which port is known to have less such issues with boards?
> >This is the embedded world. There is no cut and dry answer. Systems
> >are
> >assembled in a custom fashion to meet the application/system
> >requirements
> >at the least cost/power/weight. In this environment, there is no
> >hardware
> >that is not needed in a fielded system.
> >If you pick a self-contained embedded board with little expansion
> >capabilities
> >like the MRM332, then the BSP contains everything you can use. If
> >you choose a highly expandable board as the starting point, then
> >everything
> >on the "base board" is probably supported but not every expansion
> >capability.
> >For example, there are 1000s of PCI boards. The RTEMS PC386 BSP
> >supports
> >basic PC functionality but it is easy to pick an unsupported peripheral
> >board.
> >Similarly, many VMEbus and CompactPCI single board computers have BSPs
> >which
> >support the entire functionality on that board. But I could add a
> >peripheral
> >board or PCI mezzanine module and easily find that is not supported.
> >This philosophy is not RTEMS specific, it is a fact of life in the
> >embedded
> >world. I have consulted to projects on OS and hardware selection that
> >found
> >themselves having to balance which OS and version to use to result in
> >the
> >least development of new device drivers.
> >So the question is.. what do YOU really want to do as an application and
> >what do YOU need?
> >--joel
> >> thanks
> >> Arun
> >> On Wed, 27 Nov 2002 08:11:34
> >> >Arun Govind wrote:
> >> >> Hi,
> >> >> I am new to this group as well as to RTEMS development. I have used the i386-rtems using my pc as the target and now preparing to move to a 'real' board. Can anyone suggest which processor and board I should opt for? Or which board is 'most commonly' used for RTEMS development?
> >> >> I need all the necessary drivers for the board in the specific BSP.
> >> >You can just link them with your executable and either put them in the
> >> >device driver
> >> >configuration table or dynamically install them using
> >> >rtems_io_register_driver.
> >> >> thanks
> >> >> Arun
> >> >> _____________________________________________________________
> >> >> Get 25MB, POP3, Spam Filtering with LYCOS MAIL PLUS for $19.95/year.
> >> >> http://login.mail.lycos.com/brandPage.shtml?pageId=plus&ref=lmtplus
> >> >Joel Sherrill, Ph.D. Director of Research & Development
> >> >joel at OARcorp.com On-Line Applications Research
> >> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >> >Support Available (256) 722-9985
