How to download RTEMS to the target board ?
Keith Outwater Keith_Outwater at mvis.com
Wed Nov 27 16:40:48 UTC 2002
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Wednesday, November 27, 2002 6:10 AM
> To: Howard
> Cc: rtems-users at OARcorp.com
> Subject: Re: How to download RTEMS to the target board ?
> > Howard wrote:
> > Hi all.
> >     How to download RTEMS to the target board ? ( cpu:arm ;
> > bsp:arm_bare_bsp )
Take a look at a project called "das u-boot" on sourceforge.  U-boot supports powerpc, arm and others.  A very full-featured monitor.  I have used ppcboot (the "father" of u-boot) to boot Linux on a custom MPC860T based design and the monitor works great.  I think that RTEMS is one of the supported OSes!
Keith
Keith Outwater
Sr. Staff Engineer
Microvision, Inc.
19910 N. Creek Parkway
Bothell, WA 98011
> This is all board dependent.  You might have a ROM monitor which
> downloads across the net or download using a debugger or
> processor emulator.  So it depends upon your board.
> Worse, I think the arm_bare_bsp is an early example of an
> ARM BSP because the initial port was to a proprietary ARM
> variant.  I do not think it corresponds to any real hardware
> and is certainly not intended to be functional without work.
> I posted a couple of weeks ago about obsoleting it and removing
> it since it didn't serve a role anymore.
> >     Thanks a lot !
> >     Howard.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
