ss-20021007 available
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Mon Oct 7 18:49:47 UTC 2002
Hi,
Unfortunately, the patch which addressed IP header alignment
on the ARM had a minor typo which result in TCP/IP not compiling
on any target except ARM. So the only real difference between
ss-20021004 and ss-20021007 is this patch.
diff -N -P -r -c
rtems-ss-20021004/cpukit/libnetworking/netinet/tcp_var.h
rtems-ss-20021007/cpukit/libnetworking/netinet/tcp_var.h
*** rtems-ss-20021004/cpukit/libnetworking/netinet/tcp_var.h Fri Oct
4 09:47:11 2002
--- rtems-ss-20021007/cpukit/libnetworking/netinet/tcp_var.h Mon Oct
7 12:11:27 2002
*** 233,239 ****
m = (struct mbuf *)((((unsigned int) (ti)->ti_sport) << 16) |
( (unsigned int)(ti)->ti_dport));
#else
! #define REASS_MBUF(ti) (*(mbuf_packed **)&((ti)->ti_t))
#endif
--- 233,239 ----
#else
! #define REASS_MBUF(ti) (*(struct mbuf **)&((ti)->ti_t))
#endif
joel at OARcorp.com On-Line Applications Research
