Is newlib-1.10 required for ss-20021007?
Wed Oct 9 00:02:21 UTC 2002
How about just
  + hacking your installed pthread.h to define PTHREAD_CANCELED
    and moving on...
OR
  + revert the patch in your local cancelrun.c
--joel
Phil Torre wrote:
> I'm trying to build ss-20021007 for powerpc, and the build is
> breaking in cancelrun.c because PTHREAD_CANCELED is undefined.
> I see this in the changelog:
> 2002-08-09      Joel Sherrill <joel at OARcorp.com>
>         * src/cancelrun.c: Remove check for PTHREAD_CANCELED not being
> defined
>         to ensure that newlib patch includes it.
> I have a bad feeling that I need to get a newer newlib with the patch
> mentioned above?  (That would be bad news for me, since I am marooned
> at GDB-5.0 because my bdm debugger patch won't work with GDB 5.1 or
> newer, which keeps me from moving up to gcc 3.x.)
> If the above is correct, can I stick in a dummy define to get cancelrun.c
> built without breaking something else, or am I out of luck?
> Many thanks,
> -Phil
> Phil Torre                               phone: 425-820-6363 x234
> Design Engineer                          email: ptorre at zetron.com
> Switching Systems Group                    fax: 425-820-7031
> Zetron, Inc.                               web: http://www.zetron.com
