problems compiling latest snapshoot
Vladimir Nesic vnesic at dkts.co.yu
Mon Oct 21 11:03:44 UTC 2002
Did anybody compile latest snapshoot for m68k (68360) processor?
I have tried tools listed, but it won't work :(
binutils-2.13
gcc-3.2 		with gcc-3.2-rtems-20020819.diff
newlib-1.10.0	with newlib-1.10.0-rtems-20020809.diff
Tools copile and install, but when I try to compile snapshoot it crashes
with some gcc internal errors?
Help!
Vlada
Return-Path: <gregmatu at poczta.onet.pl>
Mailing-List: contact rtems-users-help at oarcorp.com; run by ezmlm
Delivered-To: mailing list rtems-users at oarcorp.com
Received: (qmail 5685 invoked from network); 21 Oct 2002 09:35:41 -0000
Received: from unknown (HELO smtp4.poczta.onet.pl) (213.180.130.28)
  by 0 with SMTP; 21 Oct 2002 09:35:41 -0000
Received: from f26.test.onet.pl ([192.168.240.56]:5541 "EHLO f26.test.onet.pl")
	by ps4.test.onet.pl with ESMTP id <S852965AbSJUJfA>;
	Mon, 21 Oct 2002 11:35:00 +0200
Received: from localhost ([127.0.0.1] helo=l1.test.onet.pl)
	by f26.test.onet.pl with smtp mailer
	id 183Yxf-0005na-00
	for <rtems-users at OARcorp.com>; Mon, 21 Oct 2002 11:35:00 +0200
Received: from 213.180.130.14 by 192.168.240.56 with HTTP; Mon, 21 Oct 2002 11:34:59 +0200
Received: from 193.59.197.38 by 213.180.130.14 with HTTP
To:	rtems-users at OARcorp.com
Date:	Mon, 21 Oct 2002 11:34:59 +0200
Content-Type:	text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7BIT
Content-Disposition: inline
Subject: serial conn
Mime-Version: 1.0
X-Mailer: onet.poczta
Message-Id: <E183Yxf-0005na-00 at f26.test.onet.pl>
Hi all,
On one box I have installed FreeBSD 4.6.2 and the other is to experiments - boot rtems (from floppy). This second has no monitor and I think that I can use serial conection.
I need advice/pointer how to configure serial connection on FreeBSD side. I meant not hardware but how to setup FreeBSD and how can I see what is send from rtems via com1 to com on fReeBSD - any special settings in ttys, or somthing other?
sorry for such a basic question. but
I am new to rtems and not advanced in unixces. I cant find any info regarding to reading from serial port on FreeBSD.
Thanks in advance
Gregory Matus
mailto: gregmatu at poczta.onet.pl
