POSIX, OpenH323 and RTEMS
Vladimir Nesic
vnesic at dkts.co.yu
Mon Oct 21 18:17:08 UTC 2002
On Monday 21 October 2002 14:19, Joel Sherrill wrote:
> Vladimir Nesic wrote:
> > RTEMS patch has been officialy added to opeh323 code base :)
> Yeah!! Other than openh323.org, is there anything we point to?
> Do you have a write up on RTEMS specific build procedure? There
> is at least some need to know what configure options to give RTEMS.
OK, this is the story:
Part I - the code
OpenH323 hast two libraries:
1) pwlib is platform dependent layer
2) openh323 is platform independent protocol stack
The first version of pwlib that supports rtems is 1.4.0. It can be
downloaded from http://www.openh323.org/code.html (tar.gz)
or http://www.openh323.org/~openh323/cvsweb.cgi/pwlib/ (html-cvs).
There are some restrictions on pwlib's directory location, they apply to
RTEMS as well.
Part II - compiling and makefiles
Makefile does not use RTEMS makefiles directly. The code needed has been
copy/pasted to pwlib/make/unix.mak file, under rtems section.
To make rtems version of library, I used the following:
make OSTYPE=rtems MACHTYPE=m68k CPUTYPE=mcpu32 \
HOST_PLATFORM_TYPE=linux_x86 debugnoshared
I think that openh323 lib need one or two interventions in code, but it
compiles as well.
Part III - test samples
I was not allowed to change test samples in codebase :(, so they have to
be changed manualy for RTEMS. I have attached two .h files which should
be set to specific platform and included into main.c for every sample.
They work on my platform, no guaranties for anything else :(
What must be activated is loopback driver since tlibthrd.cxx contains
socketpair function which I sent here when I was crying for pipe.
Part IV - (known) problems
File testh323.tar.gz contains sample that dies on posix_cond_signal()
> I was in the process of putting new docs online last week when I
> got derailed with another deadline.
I sow new doc's, thanks.
Vlada
> > Vlada
Type: application/x-tgz
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20021021/559a4767/attachment.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20021021/559a4767/attachment-0001.bin>
