POSIX, OpenH323 and RTEMS
Mon Oct 21 14:19:00 UTC 2002
Vladimir Nesic wrote:
> RTEMS patch has been officialy added to opeh323 code base :)
Yeah!! Other than openh323.org, is there anything we point to?
Do you have a write up on RTEMS specific build procedure?  There
is at least some need to know what configure options to give RTEMS.
> Unfortunately, it still doesnt work compleatly :(, and as much as I can
> see the problem is in posix compatibility.
> The question is: where can I find a detailed status of POSIX API?
You want the "RTEMS POSIX 1003.1 Compliance Guide".  An older version
is online at
http://www.oarcorp.com/rtemsdoc-4.5.1-pre3/rtemsdoc/html/posix1003_1/index.html
The current version of all manuals is in the source distribution under
rtems-XXX/doc/.  If you spot a mistake in the compliance list or have
a question, ask.  That document is hard to remember to update and
likely says some thigns aren't supported that actually are.
I was in the process of putting new docs online last week when I
got derailed with another deadline.
> Vlada
