Problem: Making BSD socket application (rtems-ss-20021007)
Wed Oct 30 14:21:14 UTC 2002
Reigu R wrote:
> Hi All,
>  I configured RTEMS in my linux (RedHat 7.2) installation. It was
> successfully build.The target which I opted is i686-pc-linux.
> I created a sample program which uses BSD sockets. While making the
> program, it produced the following error :
The RTEMS "unix port" is built on top of the native UNIX services
and co-exists with them.  Some RTEMS features are not supported
in this environment including POSIX threads and TCP/IP due to header
file and naming conflicts.
There is a PR filed with a patch to use dynamic loading but it has
never been merged.  With this patch, the person was able to use
the TCP/IP stack and it should be possible to enable all RTEMS
services.  If you want to review it and update it so it can be
merged, it would be most appreciated.  It was against a long ago
version of RTEMS, not submitted until it was old, and the
portability confidence factor was a bit low.  So we filed it
away until someone interested could focus on it again.
> # make
> test -d o-optimize || mkdir o-optimize
> gcc --pipe -B/opt/rtems/posix/lib/ -specs bsp_specs -qrtems -g -Wall
> -g -D_BSD_SOURCE -c -o o-optimize/init.o init.c
> In file included from /usr/include/netinet/in.h:23,
> from /usr/include/arpa/inet.h:23,
> from init.c:33:
> /opt/rtems/posix/lib/include/stdint.h:16: warning: redefinition of
> `int8_t'
> /usr/include/sys/types.h:190: warning: `int8_t' previously declared
> here
> /opt/rtems/posix/lib/include/stdint.h:17: warning: redefinition of
> `int16_t'
> /usr/include/sys/types.h:191: warning: `int16_t' previously declared
> here
> /opt/rtems/posix/lib/include/stdint.h:18: warning: redefinition of
> `int32_t'
> /usr/include/sys/types.h:192: warning: `int32_t' previously declared
> here
> /opt/rtems/posix/lib/include/stdint.h:19: conflicting types for
> `int64_t'
> /usr/include/sys/types.h:193: previous declaration of `int64_t'
> make: *** [o-optimize/init.o] Error 1
> The configure command I used is as follows :
> # ../rtems-ss-20021007/configure --target=i686-pc-linux
> --disable-itron --enable-tests --enable-cxx --enable-networking
> --enable-tcpip --enable-posix
> The error was produced only when I included either of the following
> headers :
> #include <netdb.h>
> #include<netinet/in.h>
> #include<arpa/inet.h>
> I think some headers in the RTEMS library is having similar
> declarations which conflicts the one declared in the headers of linux
> library.
> Expecting your comments on the same.
> Thanks in Advance,
> Reigs
> Do you Yahoo!?
> HotJobs - Search new jobs daily now
