as, cc, ld ... native or cross compiler? crt0.o?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Oct 15 22:02:50 UTC 2002
Tito Costa wrote:
> Joel Sherrill wrote:
> > If you built it yourself following the instructions, the precise
> > prefix is not a problem.
> > Can you try running this command: sparc-rtems-gcc -o conftest conftest.c
> > on this file:
> > main() {return 0;}
> > and let's see the output. That is ually a dead give away.
> Same error about crt0.o
> ld: fatal: file crt0.o: open failed: No such file or directory
> Using -v option, I can see that native cc1, as and ld are invoked.
> This is the command that fails:
> ld -o conftest crt0.o crti.o crtbegin.o /var/tmp/cc7cI16l.o -lgcc -lgcc
> crtend.o crtn.o
Not good. Did you install binutils in the same location before
doing gcc/newlib? I can't see why the native cc1 would be used though.
Something is definitely wrong on the tool build.
> I found the directory containing crti.o, crtbegin.o, crtend.o and crtn.o
> but crt0.o is not there. there's a crt1.o instead.
You did successfully build from source, right?
> thanks,
> tito
joel at OARcorp.com On-Line Applications Research
