Cannot find task id.
Niclas Johansson
nicjoh-7 at sm.luth.se
Wed Oct 23 12:58:56 UTC 2002
Yes on both.
This is the call:
task_status = rtems_task_ident(rtems_build_name('L','O','G','1'),
RTEMS_SEARCH_ALL_NODES, &taskid);
I find it strange that it works fine before I start the task but not
after.
/Nicke
On Wed, 23 Oct 2002 Per-Olof.Wallin at esa.int wrote:
> Per-Olof Wallin at ESA
> 10/23/2002 02:08 PM
> Are you using rtems_task_ident and if you are, did you use rtems_build_name
> to create the name?
> /Per-Olof
> | | Niclas |
> | | Johansson |
> | | <nicjoh-7 at sm.|
> | | luth.se> |
> | | 02-10-23 |
> | | 13:00 |
> | To: rtems-users at oarcorp.com |
> | cc: (bcc: Per-Olof Wallin/estec/ESA) |
> | Subject: Cannot find task id. |
> I am trying to find the id of a task from another task using
> rtems_task_ident. When the task is created it works fine and I get the
> id of the task, but when the task is started I get invalid
> name as error response. Anybody have any ideas? Getting the id seems to me
> like a straightforward operation but I cannot figure out what's wrong.
> /Nicke
