Problem building the ss20021007
Joe Samuel
sjoe2 at yahoo.com
Thu Oct 24 09:27:55 UTC 2002
Hi,
I think a bit more explanation is needed here. When
I specified the target as i686 (which is the host
platform), the process went without any glitches. If
the PATH is the problem how could this happen? How ar
and gcc could be resolved?
Are there any changes need to be made before
making for a different target. If so what are they?
thanx for your time.
Joe
--- Ralf Corsepius <corsepiu at faw.uni-ulm.de> wrote: >
Am Don, 2002-10-24 um 10.44 schrieb Paul Whitfield:
> > Joe Samuel wrote:
> > > Hi Paul,
> > > thank you for your valuable advice, but I'm
> still
> > > stuck up with something else. Here's the
> relevant
> > > build trace:
> > > ../cpukit/score/cpu/unix/cpu.c
> > > rm -f o-optimize/libscorecpu.a
> > > no ruv o-optimize/libscorecpu.a o-optimize/cpu.o
> > > gmake[6]: no: Command not found
> > Do you have a environment variable
> > called AR set to NO?
> > This could be the cause.
> No, all this indicates that your PATH is set up
> wrong and that you are
> trying to apply a non-functional or bogus toolchain.
> Furthermore, you MUST NOT set CC or GCC nor AR, NM
> or whatever from your
> environment before running configure - This
> definitely is wrong!
> Ralf
__________________________________________________
Do You Yahoo!?
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
