Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
Ian Caddy ianc at microsol.iinet.net.au
Tue Sep 3 02:03:27 UTC 2002
Hi Andrew,
We use the Coldfire 5307 in our products.  We are currently using the
4.5.0 release of RTEMS.  Once we have the products completed, then we
will look at upgrading to the snapshots.
If you have any other questions don't hesitate to contact us.
regards,
Ian Caddy
Andrew Sinclair wrote:
>Hello all,
>I am a newbie to RTEMS, and it seems that I am in the same "boat" as what
>Maarten was a year ago. So, I was wondering if anyone has ported a bsp to the
>MCF5272C3 board in the year since these emails?
>Any feedback would be much appreciated.
>Regards,
>Andrew Sinclair
>Date: Fri, 14 Sep 2001 09:44:01 -0500
>From: "Mike Siers" <mikes at poliac.com>
>Hi Maarten,
>Please check out the following URL.  The web page has some
>very useful information about Motorola Coldfire development.
>At this web site there is a link to the Netburner site and
>some old information about RTEMS.
>http://www.fiddes.net/coldfire/
>Also, I do not think you will be able to use the RPM binary
>versions of the GNU tools for Coldfire development.  This
>web site has some patches that must be applied to gcc for the
>coldfire.  And you will also want Chris John's gdb-bdm patches.
>I am working using a Coldfire 5206e evaluation board.  Below
>are the versions of the tools that I am using (built from the
>source code).
> 1) binutils-2.10 with Coldfire patches and RTEMS patch 2000-11-07
> 2) gcc-2.95.3 with Coldfire patches and RTEMS patch 2001-03-14
> 3) newlib-1.9.0 with Coldfire patches and RTEMS patch 2001-06-22
> 4) rtems snapshot 2001-08-16
>Good Luck
>Mike Siers
>>-----Original Message-----
>>From: Maarten.Kruger at ziton.spx.com [mailto:Maarten.Kruger at ziton.spx.com]
>>Sent: Friday, September 14, 2001 7:22 AM
>>To: rtems-users at OARcorp.com
>>Subject: RE: Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
>>Good day,
>>Could you provide me with a link to this Netburner 5272 board?  Is it very
>>similar to the MCF5272C3 evaluation board?  How long do you think porting
>>the BSP will take (I'm a total newbie...)
>>I have downloaded RTEMS and installed the tools, as well as ordered the
>>MCF5272C3 board, so I'm comitted now...
>>thanks
>>Maarten Kruger
>>"Brett Swimley" <brett.swimley at aedinc.net> on 2001/08/24 04:01:16 PM
>>Please respond to <brett.swimley at aedinc.net>
>>To:   <Maarten.Kruger at ziton.spx.com>
>>cc:
>>I'm in the process of doing an RTEMS port for the Netburner 5272 board.
>>I'll
>>be submitting shortly.  This should be readily adaptable to the Motorola
>>eval board.
>>Regards,
>>Brett Swimley
>>Sent: Friday, August 24, 2001 6:09 AM
>>To: rtems-users at oarcorp.com
>>Subject: Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
>>Good day,
>>Thank you for the overwhelming response on my question of using RTEMS for
>>powerPC...  It seems that the Motorola ColdFire may be more
>>appropriate for
>>my needs - is anybody using an existing port of RTEMS for the ColdFire?
>>(e.g. MFC5272C3 evalutation board?)
>>thanks
>>Maarten Kruger
Microsol (Aust) Pty Ltd
Suite 4, Enterprise Centre 3
11 Brodie Hall Drive
Bentley, WA, 6102
Phone: (+61) 08 9473 6600 Fax:   (+61) 08 9473 6699
