Problems: network on mvme162
Kossel, Torben
kossel2 at bnl.gov
Thu Sep 19 15:08:21 UTC 2002
Hi,
I tried to build RTEMS on a Linux System for the mvme162 Board with
network enable but this failed. Without networking I have no problems.
I used the rtems-ss-20020807 snap shot, the gcc 3.2 and actually newest
newlib. The i82596 ethernet driver from mvme167 BSP is used.
I confiured it with this command: ../rtems-ss-20020807/configure
--target=m68k-rtems --prefix=/opt/rtems --enable-cxx --disable-tests
--enable-posix --enable-itron --enable-maintainer-mode
--enable-rtemsbsp=mvme162 --disable-rdbg
By running the make command I got several errors located somewhere in
the files in the rtems-ss-20020807/cpukit/libnetworking/kern and the
rtems-ss-20020807/cpukit/libnetworking/sys
directory.
Thanks,
Torben
