Error while doing a "make all" while building RTEMS for leon on linux
sudhir pola
surya_hi at yahoo.com
Thu Sep 19 19:37:09 UTC 2002
Hi all,
Getting the following error while doing a make all
after configure when trying to build RTEMS on leon :
I am using rtems-4.5.
/opt/rtems/bin/sparc-rtems-gcc --pipe
-B../../../../../../leon1/lib/ -specs bsp_
specs -qrtems -g -Wall -ansi -fasm -mcpu=cypress
-msoft-float -c -O4 -o
o-optimize/init.o
../../../../../../../rtemsos/c/src/tests/samples/hello/init.c
-msoft-float -L ../../.
./../../../leon1/lib -O4 -o o-optimize/hello.exe
o-optimize/init.o ../../../.
./../../leon1/lib/no-dpmem.rel
../../../../../../leon1/lib/no-event.rel ../../..
/../../../leon1/lib/no-msg.rel
../../../../../../leon1/lib/no-mp.rel ../../../..
/../../leon1/lib/no-part.rel
../../../../../../leon1/lib/no-signal.rel ../../../
../../../leon1/lib/no-timer.rel
../../../../../../leon1/lib/no-rtmon.rel
/opt/rtems/sparc-rtems/bin/ld: cannot open linker
script file linkcmds: No such
file or directory
collect2: ld returned 1 exit status
make[5]: *** [o-optimize/hello.exe] Error 1
make[5]: Leaving directory
`/usr/local/leon/rtemsos/build/sparc-rtems/c/leon1/te
sts/samples/hello'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory
sts/samples'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
sts'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/usr/local/leon/rtemsos/build/sparc-rtems/c/leon1'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/usr/local/leon/rtemsos/build/sparc-rtems/c'
make: *** [all-recursive] Error 1
Can anyone help me out.
Thanks in advance ..
Sudhir
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
