dirent struct
Peter Mueller
peter.o.mueller at gmx.de
Sat Sep 21 14:23:21 UTC 2002
Hello,
I want to use the t_type member of the dirent struct returned from readdir() to find out if the actual dir entry is a subdir or a plain file. First t_type is not available but rec_len and the value is always the same independant of entry type. Is this currect behaviour?
Is there an other way to find out if a readdir returned a file or a dir?
Thanks,
Peter
"This is an object-oriented system.
If we change anything, the users object."
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020921/c977565c/attachment.bin>
