'configure' problem
Till Straumann
strauman at SLAC.Stanford.EDU
Fri Apr 4 04:51:25 UTC 2003
Here's one for you, Ralf:
Built powerpc-mvme2307 with my new toolchain on solaris
and it crashed. I tracked it down to improper
CFLAGS (CPU_CFLAGS is not set).
Here's what happens:
c/src/configure's first line calls for #!/bin/sh
eventually, 'configure' reads the pre-made
'<build_dir>/powerpc-rtems/c/mvme2307/make/mvme2307.cache'
which looks like this (linebreaks added by stupid
message composer):
ac_cv_env_RTEMS_CPU_MODEL=${ac_cv_env_RTEMS_CPU_MODEL=mpc604}
ac_cv_env_RTEMS_BSP_FAMILY=${ac_cv_env_RTEMS_BSP_FAMILY=motorola_powerpc}
ac_cv_env_CPU_CFLAGS=${ac_cv_env_CPU_CFLAGS=-mcpu=604 -mmultiple mstring
-mstrict-align}
ac_cv_env_CFLAGS_OPTIMIZE_V=${ac_cv_env_CFLAGS_OPTIMIZE_V=-O4}
ac_cv_env_CFLAGS_DEBUG_V=${ac_cv_env_CFLAGS_DEBUG_V=-O1}
ac_cv_env_CFLAGS_PROFILE_V=${ac_cv_env_CFLAGS_PROFILE_V=-O1 }
However, solaris' /bin/sh executing 'configure' doesn't seem to grok the
var=${var=value}
constructs.
configure complains but runs through (and the complaint went
undetected) but fails to build a correct Makefile
(i.e. it builds a Makefile but doesn't set CPU_CFLAGS).
Any ideas about what went wrong greatly appreciated
--Till
PS: I did 'bootstrap' on a different system than the
'configure/build/install' but I thought that should
be OK.
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20030403/7fadbde3/attachment.bin>
