how to configure dosfs on pc386 targets and how to use it
Angelo Fraietta
angelo_f at bigpond.com
Fri Apr 4 02:39:18 UTC 2003
维 戴 wrote:
> Hello all,
> I hada problem a _long_ time ago. I want to configure rtems' dosfs
> onthe hard disks. But I don't know how to configure it on pc386
> targets and how to use it. The version of the rtems is rtems-ss-20021118.
> Thanks for any help!
> David
This is a cut and paste from messages about a month ago
Thomas Doerfler wrote:
Hello Angelo,
the "sample" program is located in the patch filed in the gnat
system as PR369. So if you go to
http://www.oarcorp.com/cgi-bin/gnatsweb.pl
and inspect PR369 and download/apply the patch and then look
into c/src/tests/samples/fileio, you will see the sample
application.
BTW, you will also need PR368 and PR367 to get everything
running (these PRs contain modifications for the DOSFS code
and added drivers for PC386 and MBX8xx).
Yes, since the rtems source tree has been modified (some
directories added etc) you will have to "bootstrap" the
autoconf/automake files to get them up to date. So you hae to
install the proper autoconf/automake versions for rtems-
4.6.0pre1 (see the tool versions specified either in the
source tree or on the OAR ftp site), and then go to the rtems
source tree base directory and type
./bootstrap
Make sure to have some coffee and a good book nearby, because
this procedure take a lot of time.
wkr,
Thomas
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030404/b65f0089/attachment-0001.html>
