Bare configuration problem --enable-bare-cpu-cflags
Stephen Holford
SHolford at wescam.com
Mon Apr 7 18:35:12 UTC 2003
Hi
I've just noticed a problem with rtems-4.6.0pre that
--enable-bare-cpu-cflags no longer seems to work. The flags get parsed
and appear in BARE_CPU_CFLAGS, but the assignment
CPU_CFLAGS=$(BARE_CPU_CFLAGS) in bare.cfg doesn't seem to work. I can
hard code "CPU_CFLAGS=-O2 blah blah" in bare.cfg and that does work.
As a work around I have found that using the CFLAGS_FOR_TARGET
environment variable before ./configure does allow me to pass the flags
I need to build correctly. Is this now the preferred way to pass in
CFLAGS to the build process rather than --enable-bare-cpu-cflags?
Steve
Stephen F. Holford, P.Eng.
Wescam
