gdb use serial port
zhangxiaoxian zhangxiaoxian at ecict.com.cn
Tue Apr 29 06:04:27 UTC 2003
Hi
I'm debugging rtems application through serial port. I used the following gdb command 'target remote com2' to specify serial port number for target machine.
The question is: where to specify serial port number for host machine? Or is it possible to use com1 on host and com2 for target?
Thank you.
Zhang Xiaoxin
