4.6pre1, make VARIANT=DEBUG, no librtems++_g.a
Brett Swimley
brett.swimley at aedinc.net
Tue Apr 29 22:54:12 UTC 2003
Did this ever get fixed? I seem to get this same behavior with rtems-ss-20030417.
I get no *_g.rel files placed in my lib directory.
What was the fix, if made, so that I can confirm that it is applied in the snapshot?
Thanks,
Brett Swimley
Quoting Ralf Corsepius <corsepiu at faw.uni-ulm.de>:
> Am Die, 2003-03-04 um 03.53 schrieb Wendell Thompson:
> > I've built 4.6pre1 for a custom bsp, with VARIANT=DEBUG.
> > It appears that everything else in lib built correctly, but not
> > librtems++_g.a:
> Thanks, you have found a bug.
> librtems++_g.currently gets pre-installed inside of the source tree, but
> is not installed to the final destination
> I am about to fix this, ASAP.
> Ralf
Brett Swimley
Advanced Electronic Designs
406-585-8892 / 406-585-8893 (fax)
