libblock real-time behavior
Till Straumann
strauman at slac.stanford.edu
Thu Apr 10 15:55:20 UTC 2003
Joel Sherrill wrote:
>Chris Johns wrote:
>>Till Straumann wrote:
>>>I was (again) thinking of using 'libblock' for adding
>>>caching to my NFS driver.
>>>However, I'm concerned about preemption-disabled
>>>sections in libblock.
>>So you should be.
>>>Are these sections deterministic - what's the
>>>"longest" preemption-disabled section to be expected?
>>>Code like
>>>DISABLE_PREEMPTION()
>>>free(something);
>From memory, this is a constant time operation.
Still unnecessarily stealing cycles from higher priority threads...
And then, I can't see how this approach can provide protection
on a multiprocessor system but I believe to have asked this
in the past and must admit that I still haven't looked into RTEMS MP...
-- Till.
>A task can block when no memory is available from a region
>(which malloc/free use) but malloc() does not
>block for memory when none is available. When memory is
>freed and tasks are blocked, the memory will be parceled out
>to as many blocked tasks as possible.
>But if no tasks are waiting for memory (as is the case
>with malloc/free), then the operation only does a bit
>of accounting to coalescesce with the previous and/or
>next block if they are free. See cpukit/score/src/heapfree.c
>for precise details.
>>>ENABLE_PREEMPTION();
>>>do not greatly enhance my confidence (I'd rather call 'free'
>>>outside of the critical section).
>>Is the use of this macro local to libblock ?
>Yes in fact the macros are defined twice -- once in ata.c and once in
>bdbuf.c
>>If so is it possible to change these defines to LIBBLOCK_LOCK and LIBBLOCK_UNLOCK and
>>then reference a mutex (see network stack glue for an example) ?
>I would think it is possible and likely faster if there are no
>contention for the mutex.
>>(I ask this with-out actually checking any code)
>:) Application of design patterns seldom requires that unless you are
>implementing
>or debugging it. :)
>> Chris Johns, cjohns at cybertec.com.au
