libblock real-time behavior
Valette Eric
eric.valette at free.fr
Thu Apr 10 16:22:11 UTC 2003
Till Straumann wrote:
> And then, I can't see how this approach can provide protection
> on a multiprocessor system but I believe to have asked this
> in the past and must admit that I still haven't looked into RTEMS MP...
> -- Till.
If you want RTEMS SMP (different cache same physical memory, shread
interrupt controller), then believe me, there is a rather huge amount of
redesign needed :
1) Today, most critical section locking are performed via interrupt
disabling/reenabling which of course does not work in a MP system,
2) The interrupt disable/reenable use level so they can be arbitrily
nested without any notion of locking heirarchy so remplacing them by
maskedspilock will probably lead to immediate deadlock,
3) Some structure need to be per cpu (e.g currentask, ...) and there is
no real provision for that
I do not even speak of cache coherency problem on system where bus
snooping must be specifically enabled...
BTW : ecos 2.0 starts to have some SMP code in it...
__
/ ` Eric Valette
/-- __ o _. 6 rue Paul Le Flem
(___, / (_(_(__ 35740 Pace
Tel: +33 (0)2 99 85 26 76 Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
