pr386
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 14 15:48:16 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> It seems there may have been patch problems with this snapshot. The
> link problem can be resolved by modifying file
> c/src/lib/libbsp/powerpc/shared/irq/irq.c
> making line 323;
> extern int _BSP_vme_bridge_irq;
> as this variable is also defined and set in vme.c. I have sucessfully
> re-run our software on the mcp750 with this change in place- should be
> fine as its not a vme board. Hopefully someone can test this snapshot
> on a vme system.
Thanks Greg. Without being sure, I put the extern in vmeconfig.c.
I think this is the area in the code where I ran into patch rejects.
Hopefully Till will tell us which solution is the one he wants.
> Gregm
joel at OARcorp.com On-Line Applications Research
