pr386
Till Straumann
strauman at SLAC.Stanford.EDU
Mon Apr 14 18:16:50 UTC 2003
Joel Sherrill wrote:
> gregory.menke at gsfc.nasa.gov wrote:
>>It seems there may have been patch problems with this snapshot. The
>>link problem can be resolved by modifying file
>>c/src/lib/libbsp/powerpc/shared/irq/irq.c
>>making line 323;
>>extern int _BSP_vme_bridge_irq;
>>as this variable is also defined and set in vme.c. I have sucessfully
>>re-run our software on the mcp750 with this change in place- should be
>>fine as its not a vme board. Hopefully someone can test this snapshot
>>on a vme system.
> Thanks Greg. Without being sure, I put the extern in vmeconfig.c.
> I think this is the area in the code where I ran into patch rejects.
> Hopefully Till will tell us which solution is the one he wants.
On 2003/03/21 I moved _BSP_vme_bridge_irq from shared/vme/vmeconfig.c
to shared/irq/irq.c. My log says:
define _BSP_vme_bridge_irq in 'irq.c' rather than vmeconfig.c
to avoid vmeUniverse being linked even if vmeconfig()/vmeUniverse
is not used otherwise (that's actually the whole purpose of
the _BSP_vme_bridget_irq variable).
Hence line 323 (this line number is prior to applying #377) should be
int _BSP_vme_bridge_irq = -1;
and any definition of this variable should be removed from vmeconfig.c
The patch addressing this issue was #349.1
HTH
-- Till
>>Gregm
