(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta angelo_f at bigpond.com
Wed Apr 16 00:39:20 UTC 2003
>> I have implemented this into my app, hwoever, when I try to examine
>> the file, I get zero bytes.
>> I did the following
>>     fd = open(nvram_file,O_WRONLY | O_CREAT | O_TRUNC,S_IREAD|S_IWRITE);
>>     if (fd <0)
>>             printf ("Unable to open %s\r\n", nvram_file);
>>     else
>>             unsigned i;
>>             for (i = 0; i < 255; i++)
>>                     char c = (char) i;
>>                     int bytes = write(fd, &c, 1);
>>                     printf ("Wrote %u bytes \r\n", bytes);
>>             close(fd);
>>             printf ("Close file\r\n");
> After running test example again, I have noticed that the file does
> not actually get written to the disk unless I write another file after
> writing the first. The second file has a size of zero bytes.
> In my application, I have tried doing this also, however, the second
> file does not get created and the first file is zero bytes. I am
> running mine in a low priority task (the other are currently blocked
> thorugh). Is there some limitation to the task type at all?
I have found that listing the directory after closing the file seems to
do the trick. It must purge the buffers to the disk.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
