4.6.0pre3 available
Chris Johns cjohns at cybertec.com.au
Sat Apr 26 05:50:28 UTC 2003
Joel Sherrill wrote:
> pre2 had a minor glitch and one file incorrectly
> reported that it was still pre1.  THis was due to
> a CVS commit hiccup during the cut_release script
> being run.  No other changes were made.
> This is only to address a packaging problem. :(
> FWIW the cut_release script was modified to detect
> that the source exported from CVS that is used to
> make the release tarball does in fact have the
> right versions in the appropriate files.
> Now we can worry about what real problems need to be
> there. :)
Minor issue:
test -d ../../../lib//m5200 || /bin/sh  ....
m68k-rtems-ar rc ../../../lib//m5200/librtemscpu.a o-optimize/*
This is with "--enable-multilib". Should this happening ?
  Chris Johns, cjohns at cybertec.com.au
