4.6.0pre3 available
Mon Apr 28 13:08:20 UTC 2003
Ralf Corsepius wrote:
> Am Son, 2003-04-27 um 13.53 schrieb Joel Sherrill:
> > Angelo Fraietta wrote:
> > > Is this one of those patches that requires me to do a bootstrap again?
> > > I applied the patch but it didn't work
> > At least run autoconf
> In this case: automake would have been correct.
Duhh!  I knoew that.  Sorry.
> automake generates Makefile.ins from Makefile.ams.
> As this patch modifies a Makefile.am, you at least need to regenerate
> the Makefile.in.
> >  from the nearest directory uptree that has a
> > configure.ac.
> Alternative: configure your source-tree using --enable-maintainer-mode
> The configuration the will automatically update the files.
Ralf's right.  THis is definitely the handiest way.
> Ralf
