Error During Make for i386ex BSP - Beginner HELP
Aditya
avpenu at essex.ac.uk
Tue Aug 12 13:10:45 UTC 2003
After Sucessful configuration of RTEMS (it says to do a make all at the
end)....I do ... make all install ... as said in the RTEMS Getting
Started c/++ manual...
and i get an error like this below at the end...
mkdir o-optimize
/opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../i386ex/lib/
-specs bsp_specs -qrtems -g -Wall -ansi -fasm
-c -O4 -o o-optimize/init.o
../../../../../../../archive/c/src/tests/samples/hello/init.c
-L ../../../../../../i386ex/lib -O4 -o o-optimize/hello.coff
o-optimize/init.o ../../../../../../i386ex/lib/no-dpmem.rel
../../../../../../i386ex/lib/no-event.rel
../../../../../../i386ex/lib/no-msg.rel
../../../../../../i386ex/lib/no-mp.rel
../../../../../../i386ex/lib/no-part.rel
../../../../../../i386ex/lib/no-signal.rel
../../../../../../i386ex/lib/no-timer.rel
../../../../../../i386ex/lib/no-rtmon.rel
/opt/rtems/i386-rtems/bin/ld:../../../../../../i386ex/lib/linkcmds:115:
parse error
collect2: ld returned 1 exit status
make[5]: *** [o-optimize/hello.exe] Error 1
make[5]: Leaving directory ..................
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory...............
make[3]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
ETC...
May i know the cause of this error and how to rectify it?
Regards
Aditya <http://privatewww.essex.ac.uk/~avpenu>
URL: <http://lists.rtems.org/pipermail/users/attachments/20030812/534f00a5/attachment.html>
