I386ex board - Beginner Help
Aditya
avpenu at essex.ac.uk
Thu Aug 21 17:25:46 UTC 2003
Dear RTEMS Users,
Sorry for troubling you again,
The following is a memory map for my i386ex based board...It uses an AMD
AM29F040B(512 K) flash memory device.
-Range-
<Start> <End>
DRAM 00000000 003fffff
CAN Controller 000e0000 000e007f
LEDs + EEPROM 000e0080 000e00ff
EthernetInterface 340 35f
Ethernet RAM 000c0000 000dffff
EPROM/FLASH 03f80000 03ffffff
I'm giving these details as I need to know where are the changes need to
be done to reflect these conditions in the RTEMS code. (I think in
linkcmds..Correct me if im wrong)...
I think that Start.S does the loading from ROM to RAM...do I need to
chane it for this memory map..If yes where?
Is it enough to run the sample applications on the board directly by
loading them on flash?
OR Is it required to load the OS on the flash and then load the
application on top of it for the sample applications like hello.exe to
run?
I think that the Hello.exe (and other samples also) includes the RTEMS
kernel and other BSP startup code.
Please correct me If im wrong...
Regards
Aditya
