On Thursday 21 August 2003 17:45, you wrote: > This is a gcc internal file and is supposed to be found automatically > when calling powerpc-rtems-g++. If it doesn't, this would indicate a bug > in gcc. > > You may want to check powerpc-rtems/c/<BSP>/librtems++/config.log for > details about what may go wrong. Many thanks you, Ralf. It helped. leonp at plris dot com
