new() error
Francesco Poletti
fpoletti at libero.it
Tue Aug 26 21:21:43 UTC 2003
Hy all, it seems to be a very strange errors...
The main questions is: does someone know how the new() functions is linked to
RTEMS and in particoularly with the rtems_region_allocator or the heap?
I have also try to see where may have been defined the "new()" functions but I
don't found it. Need I to manually add this functions and to link it with one
allocator?
In my case I can compile the rtems++ tests.
Thanks to all Francesco.
> Francesco Poletti wrote:
> > Hy all,
> > I'm trying to see if is possible to use c++ on my board (which I have personally
> > wrtitten for an arm starting by an existing one.)
> > Now I'm able to compile an application which define static object, the only
> > problem is that I can't use new(), because when I try compile the compiler give
> > to me that error:
> > /scratch/francesco/initialc++/init.cpp:44: undefined reference to `operator
> > new(unsigned long)'
> > delete(void*)'
> > delete(void*)'
> > /scratch/francesco/initialc++/init.cpp:51: undefined reference to
> > `__gxx_personality_sj0'
> > Someone know if is possible to have a board which use it? If yes what I need to
> > had in order to have it working?
> Yes. And this is probably he result of missing some sections that are
> C++ specific in yout linkcmds. Check your BSP's linkcmds against
> another one. I think you are on an ARM so check the edp7312. I am
> pretty sure Jay Monkman tested C++.
> > Really thanks to all Francesco.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
