a strange problem with rtems_io_register_name
Stan zylog at club-internet.fr
Thu Aug 28 19:36:58 UTC 2003
----- Original Message -----
To: rtems-users at rtems.com
Sent: Thursday, August 28, 2003 5:12 PM
Subject: Re: a strange problem with rtems_io_register_name
From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
> According to the code, this indicates that mknod()
> failed (cpukit/src/imfs/ioman.c).  Can you
> break at RTEMS_Malloc_Initialize and see how much
> heap you are actually allocating?  I suspect that
> you don't have much at all like almost 0. :)
No, heap count 8192 byte (0x2000).
> This should be one of the first attempts to malloc
> memory in the boot sequence.
In that case, why mknod don't failed in main task ?
How to check simply the filesystem for remove this ambiguity ?
  Thanks
  Stan.
