a strange problem with rtems_io_register_name
Thu Aug 28 20:49:20 UTC 2003
Stan wrote:
> ----- Original Message -----
> From: Stan
> To: rtems-users at rtems.com
> Sent: Thursday, August 28, 2003 5:12 PM
> Subject: Re: a strange problem with rtems_io_register_name
> From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
>>According to the code, this indicates that mknod()
>>failed (cpukit/src/imfs/ioman.c).  Can you
>>break at RTEMS_Malloc_Initialize and see how much
>>heap you are actually allocating?  I suspect that
>>you don't have much at all like almost 0. :)
> No, heap count 8192 byte (0x2000).
Can't you make it bigger than that?  I would rather see something
like 64K until you know that low memory isn't an issue.
>>This should be one of the first attempts to malloc
>>memory in the boot sequence.
> In that case, why mknod don't failed in main task ?
This runs before the first task.
> How to check simply the filesystem for remove this ambiguity ?
I suppose it could do something more specific with the error
returned by mknod().  Suggestions welcomed.
>   Thanks
>   Stan.
