Ethernet support
Ed Sutter
els at emailbox.hdtv.lucent.com
Mon Aug 4 17:17:09 UTC 2003
I just used MicroMonitor as the boot platform for getting my
RTEMS application up. It has BOOTP, DHCP & TFTP for downloading
the application. While debugging the bsp I was able to insert monitor
based hooks that allowed me to insert printfs() into the RTEMS startup
code to quickly get the BSP running. With that as the bootloader, the
RTEMS application is just an ELF file in the monitor's flash file system,
which, by the way, is accessible by the RTEMS application out-of-the-box.
If anyone is interested, let me know. Or take a peek at...
http://www.microcross.com/Support/umon/umon.html
Ed
Till Straumann wrote:
> Joel Sherrill wrote:
> > Madhu Raju wrote:
> >>> ===== Original Message From Joel Sherrill <joel at OARcorp.com> =====
> >>> Madhu Raju wrote:
> >>>> Hi,
> >>>> I have a DY4 SVME board.Right now I am downloading an application
> >>>> onto the
> >>>> board through a serial port connection.How can I download it using
> >>>> ethernet?
> >>>> So that I could download it faster..
> >>>> Thanking in advance,
> >>>> Madhu
> >>> The simplest way would be to use the ROM monitor provided with the board
> >>> to do it. Does it have a TFTP client or any commands to boot from the
> >>> network?
> >>> I know that the Motorola, Vista SCORE603e and Radstone boards could
> >>> do this.
> >>> --joel
> >> I dont think the powerpc monitor has any commands to do this.Any other
> >> way?
> > Write a simple RTEMS program that you burn into the Flash on this board
> > that downloads
> > into memory. I believe that Eric Norum has had to do something similar
> > on a board he uses
> > so he might have some code to start from.
> I also had the same problem on my powerpc board. Althought the firmware
> monitor can download via TFTP, it was awfully slow and the firmware
> can't do BOOTP etc.
> Therefore, I created a simple RTEMS application which can do all this.
> If that's what you need - let me know and I can provide you with what
> I have...
> -- Till
> >> Thank you,
> >> Madhu
