Ethernet support
Till Straumann strauman at SLAC.Stanford.EDU
Mon Aug 4 16:59:10 UTC 2003
Joel Sherrill wrote:
> Madhu Raju wrote:
>>> ===== Original Message From Joel Sherrill <joel at OARcorp.com> =====
>>> Madhu Raju wrote:
>>>> Hi,
>>>> I have a DY4 SVME board.Right now I am downloading an application
>>>> onto the
>>>> board through a serial port connection.How can I download it using
>>>> ethernet?
>>>> So that I could download it faster..
>>>> Thanking in advance,
>>>> Madhu
>>> The simplest way would be to use the ROM monitor provided with the board
>>> to do it.  Does it have a TFTP client or any commands to boot from the
>>> network?
>>> I know that the Motorola, Vista SCORE603e and Radstone boards could
>>> do this.
>>> --joel
>> I dont think the powerpc monitor has any commands to do this.Any other
>> way?
> Write a simple RTEMS program that you burn into the Flash on this board
> that downloads
> into memory.  I believe that Eric Norum has had to do something similar
> on a board he uses
> so he might have some code to start from.
I also had the same problem on my powerpc board. Althought the firmware
monitor can download via TFTP, it was awfully slow and the firmware
can't do BOOTP etc.
Therefore, I created a simple RTEMS application which can do all this.
If that's what you need - let me know and I can provide you with what
I have...
-- Till
>> Thank you,
>> Madhu
