Does somebody know the destiny of this item?
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Aug 12 17:10:54 UTC 2003
Joel Sherrill wrote:
> Leon Pollak wrote:
>> Hello.
>> One month ago Till Straumann wrote about the bug in
>> 'new_exception_processing' code. Where there some actions about this
>> since that time or the problem exists in MPC860 BSPs?
> The fix is in the libbsp/powerpc/shared code plus some tinkering in the
> score so I think the
> MPC860 BSPs are fixed.
I fixed all libbsp/powerpc/xxx BSPs which are using new exception
processing, not only the 'shared' one - although I could test only
the 'shared' BSP. However, there are no real differences between the
affected files. Ideally, that code would be inherited rather than
copied...
Note that I also inserted a few lines of paranoia code into 'score'
(I believe) - so that an unfixed new-exception BSP will panic.
-- Till
> --joel
>> Thanks ahead.
>> On Thursday 10 July 2003 21:00, Till Straumann wrote:
>> I recently experienced corruption of the 'tick' queue
>> on my PPC. I finally found out one of the reasons:
>> _ISR_Nest_level
>> on which the watchdog timer queues rely
>> is still not maintained on 'new_exception_processing' style
>> PPC BSPs other than mpc8260ads!!!
>> PR288 never made it to other PPC BSPs.
>> watch out
>> -- Till
>> As a quick workaround, you can delete the line
>> _ISR_Flash()
>> in the file cpukit/score/src/watchdoginsert.c
>> (your IRQ latency will go up)
>> (old_exception_processing BSPs are not flawed)
>> T.
