serial connections to embedded targets
Fernando RUIZ CASAS
correo at fernando-ruiz.com
Mon Aug 25 14:42:10 UTC 2003
On Mon, 25 Aug 2003 10:16:22 +0900, "Raja Saleru" wrote:
Hi,
You can start both serial shell and telnet shell in a multiterminal environment.
You have it ready to use in libmisc/shell and .../rtems_telnet/.
But only a shell for every device or pseudodevice is availiable.
The users can be 'root' or 'user' and a blank password.
You can to use HyperTerm or standard telnet to connect with your Board.
And you can implementate your new commands with a new function with the prototype
int new_command(int argc, char[] argv);
There you can to use printf() to print your results.
Every session is like a linux terminal session.
Till Staumman has built CEXP and more in order to enhance all of this.
My code is only to test and monitoring the hardware and the daemons running in the BSP.
It is poor by enough.
BRGDS
Fernando RUIZ
> Is there any other alternative which supports both serial and ethernet
> (TCP/IP) ?
> - raja
> ----- Original Message -----
> From: Bill Gatliff <bgat at billgatliff.com>
> To: <chris at chriscaudle.org>
> Cc: <rtems-users at rtems.com>
> Sent: Sunday, August 24, 2003 10:19 AM
> Subject: Re: serial connections to embedded targets
> > Chris:
> > I always use minicom. Never tried to do it with xterm, in fact.
> > b.g.
> > Chris Caudle wrote:
> > >This is a little sideways to direct RTEMS topics, but does anyone on the
> > >list know how to connect an xterm (or similar KDE or Gnome terminal
> > >program) directly to a serial port?
> > >My embedded targets typically use a serial port for string output, which
> I
> > >can view using Hyperterm on Windows, or can view by using cat to output
> > >the contents of /dev/ttyS0 in Linux. On Windows, Hyperterm is
> > >bidirectional, so I can send commands back to the embedded target, and I
> > >would like to be able to do the same thing from an xterm. It seems it
> > >should be simple, but I can't figure out how to get xterm connected to
> > >/dev/ttyS0 instead of to a shell process.
> > >thanks,
> > >Chris Caudle
> > Bill Gatliff
> > Get real embedded GNU training from a real embedded GNU developer.
