serial connections to embedded targets
Raja Saleru
iap_sraja at access.co.jp
Tue Aug 26 02:11:17 UTC 2003
I mean tranfering data from host to target and vice verse through serial and
TCP\IP like hyperterminal in windows.
- raja
----- Original Message -----
To: "Raja Saleru" <iap_sraja at access.co.jp>
Cc: <chris at chriscaudle.org>; <rtems-users at rtems.com>
Sent: Monday, August 25, 2003 9:44 PM
Subject: Re: serial connections to embedded targets
> Raja:
> Not sure what you're asking...
> I have a LAN here; I telnet to the machine with the serial connection to
> the target, and launch minicom from it. So, I can "see" the target's
> serial output from anywhere on my network.
> HTH,
> b.g.
> Raja Saleru wrote:
> >Is there any other alternative which supports both serial and ethernet
> >(TCP/IP) ?
> >- raja
> >From: Bill Gatliff <bgat at billgatliff.com>
> >To: <chris at chriscaudle.org>
> >Cc: <rtems-users at rtems.com>
> >Sent: Sunday, August 24, 2003 10:19 AM
> >>Chris:
> >>I always use minicom. Never tried to do it with xterm, in fact.
> >>b.g.
> >>Chris Caudle wrote:
> >>>This is a little sideways to direct RTEMS topics, but does anyone on
the
> >>>list know how to connect an xterm (or similar KDE or Gnome terminal
> >>>program) directly to a serial port?
> >>>My embedded targets typically use a serial port for string output,
which
> >I
> >>>can view using Hyperterm on Windows, or can view by using cat to output
> >>>the contents of /dev/ttyS0 in Linux. On Windows, Hyperterm is
> >>>bidirectional, so I can send commands back to the embedded target, and
I
> >>>would like to be able to do the same thing from an xterm. It seems it
> >>>should be simple, but I can't figure out how to get xterm connected to
> >>>/dev/ttyS0 instead of to a shell process.
> >>>thanks,
> >>>Chris Caudle
> >>Bill Gatliff
> >>Get real embedded GNU training from a real embedded GNU developer.
> Bill Gatliff
> Embedded GNU, Linux, and other board support packages.
