c++, new() error
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 26 19:35:07 UTC 2003
Francesco Poletti wrote:
> Hy all,
> I'm trying to see if is possible to use c++ on my board (which I have personally
> wrtitten for an arm starting by an existing one.)
> Now I'm able to compile an application which define static object, the only
> problem is that I can't use new(), because when I try compile the compiler give
> to me that error:
> /scratch/francesco/initialc++/init.cpp:44: undefined reference to `operator
> new(unsigned long)'
> delete(void*)'
> delete(void*)'
> /scratch/francesco/initialc++/init.cpp:51: undefined reference to
> `__gxx_personality_sj0'
> Someone know if is possible to have a board which use it? If yes what I need to
> had in order to have it working?
Yes. And this is probably he result of missing some sections that are
C++ specific in yout linkcmds. Check your BSP's linkcmds against
another one. I think you are on an ARM so check the edp7312. I am
pretty sure Jay Monkman tested C++.
> Really thanks to all Francesco.
joel at OARcorp.com On-Line Applications Research
