a strange problem with rtems_io_register_name
Fri Aug 29 11:26:42 UTC 2003
Stan wrote:
>>Can't you make it bigger than that?  I would rather see something
>>like 64K until you know that low memory isn't an issue.
>I tryed to change _HeapSize in linkcmds with 0x10000 and 0x0.
>RTEMS_Malloc_Initialize don't fail.
>With _HeapSize=0, rtems allocate 448Ko for heap.
>>>>This should be one of the first attempts to malloc
>>>>memory in the boot sequence.
>>>In that case, why mknod don't failed in main task ?
>>This runs before the first task.
>If mknod fail in the boot sequence, why don't fail after ?
>Reverse it stands to reason.
Let's go back to basics then.
What test are you running and have you modified it?
>>>How to check simply the filesystem for remove this ambiguity ?
>>I suppose it could do something more specific with the error
>>returned by mknod().  Suggestions welcomed.
>Has anybody used the mcf5206elite bsp (on latest ss-20030703) ?
>I have other custom bsp based upon efi68k on this latest;
>It work properly ...
>I don't how to solve this problem :(
>Stan, sad.
