Problem with rtems_task_variable_delete
Dieter Schaefer Dieter.B.Schaefer at t-online.de
Mon Dec 8 21:58:15 UTC 2003
Hello,
trying to get telnetd to work (powerpc, rtems-4.6.0pre5) I experienced
the following problem ...
trying various commands everything seems to work Ok, until I try to
logoff from the telnet session. The system crashes, mean end up
in the BSP panic handler.
Digging into the problem, it seems to be related with deleting a task variable.
If the task variable contains a pointer to malloc'ed memory and 'free' is
passed to rtems_task_variable_add it will crash on deleting the task.
Background: telnetd uses shell, and shell creates a 'user environment'
after issuing a 'logoff', shell tries to execute a
rtems_task_delete( RTEMS_SELF );
which in turn, at some point calls
rtems_task_variable_delete(RTEMS_SELF, ... );
The same behavior can be reproduces with a slightly modified version
of 'ticker test'
Adding a task variable pointing to malloc'ed space, assign different values
etc. and deleting this space manually after 'rtems_task_variable_delete'
everything works Ok. Passing 'free' to automatically delete this space, it
ends up in the BSP panic handler.
Did anybody experienced the same/similar problem? Or, even better,
has a fix or work-around?
Any information or hint is appreciated.
Thanks
Dieter Schaefer
PS: FTP and Web-Server runs all day long even under heavy load and
with continuous ping on FEC and SCCx.
