Problem with rtems_task_variable_delete
Till Straumann
strauman at slac.stanford.edu
Tue Dec 9 06:26:31 UTC 2003
This might be caused/related to an issue discussed a few months ago (see
PR#504)
hopefully there is more in the list archives...
the appended file implements a workaround. It needs to be linked to the
application
with -Wl,--wrap,free
Note that this is a workaround until a final solution is implemented.
HTH
-- Till
Paul Whitfield wrote:
> Dieter Schaefer wrote:
>> Hello,
>> trying to get telnetd to work (powerpc, rtems-4.6.0pre5) I
>> experienced the following problem ...
>> trying various commands everything seems to work Ok, until I try to
>> logoff from the telnet session. The system crashes, mean end up in
>> the BSP panic handler.
>> Digging into the problem, it seems to be related with deleting a task
>> variable.
>> If the task variable contains a pointer to malloc'ed memory and
>> 'free' is passed to rtems_task_variable_add it will crash on deleting
>> the task. Background: telnetd uses shell, and shell creates a 'user
>> environment' after issuing a 'logoff', shell tries to execute a
>> rtems_task_delete( RTEMS_SELF ); which in turn, at some point calls
>> rtems_task_variable_delete(RTEMS_SELF, ... );
>> The same behavior can be reproduces with a slightly modified version
>> of 'ticker test' Adding a task variable pointing to malloc'ed space,
>> assign different values etc. and deleting this space manually after
>> 'rtems_task_variable_delete' everything works Ok. Passing 'free' to
>> automatically delete this space, it ends up in the BSP panic handler.
>> Did anybody experienced the same/similar problem? Or, even better,
>> has a fix or work-around?
> Yes I have seen a similar problem with the Telnetd and
> rtems_task_variables.
> My solution was to remove the rtems_task_variable from the shell!
> Not a particularly good solution. This was with 4.5.0 so I was assuming
> that I had caused the problem by using a current version of the telnetd
> code with an old version of rtems.
> Regards
> Paul
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20031208/7b8d9756/attachment.ksh>
