Problem with rtems_task_variable_delete
Fernando RUIZ CASAS correo at fernando-ruiz.com
Tue Dec 9 09:18:32 UTC 2003
On Mon, 08 Dec 2003 22:58:15 +0100, Dieter Schaefer wrote:
Hi,
  The same problem ago.
  A patch has be submitted longtime ago to resolve this concern.
  The problem is that a new implementation of core has been done.
  The problem is in
  /rtems/cpukit/rtems/src/taskvariabledelete.c
  at line 59
   _Workspace_free(tvp) needs be changed by
   _Workspace_free(*tvp) perhaphs. (I can't test it,sorry)
  It's a problem resolved but with the new implementation the problem arrives again.
  A lot of mails have been interchanged with Joel to obtain a patch in the core.
  BRGDS.
  The author of rtems_telnetd.
> Hello,
> trying to get telnetd to work (powerpc, rtems-4.6.0pre5) I experienced
> the following problem ...
> trying various commands everything seems to work Ok, until I try to
> logoff from the telnet session. The system crashes, mean end up
> in the BSP panic handler.
> Digging into the problem, it seems to be related with deleting a task variable.
> If the task variable contains a pointer to malloc'ed memory and 'free' is
> passed to rtems_task_variable_add it will crash on deleting the task.
> Background: telnetd uses shell, and shell creates a 'user environment'
> after issuing a 'logoff', shell tries to execute a
> rtems_task_delete( RTEMS_SELF );
> which in turn, at some point calls
> rtems_task_variable_delete(RTEMS_SELF, ... );
> The same behavior can be reproduces with a slightly modified version
> of 'ticker test'
> Adding a task variable pointing to malloc'ed space, assign different values
> etc. and deleting this space manually after 'rtems_task_variable_delete'
> everything works Ok. Passing 'free' to automatically delete this space, it
> ends up in the BSP panic handler.
> Did anybody experienced the same/similar problem? Or, even better,
> has a fix or work-around?
> Any information or hint is appreciated.
> Thanks
> Dieter Schaefer
> PS: FTP and Web-Server runs all day long even under heavy load and
> with continuous ping on FEC and SCCx.
FTP calls chroot() and chroot() builds a nes user environment the same way that telnetd.
but FTPD runs forever.
