Problem with ATA driver on pc386
Eugene Denisov dea at sendmail.ru
Fri Dec 12 10:24:31 UTC 2003
Thank you, I'll try 4.6.0pre4.
I suspected the problem is in 4.6.0pre5, it seems this release is rather
raw, at least PCI support in i386 platform is broken and I had to modify
sources slightly.
----- Original Message -----
From: "Angelo Fraietta" <afraiett at bigpond.net.au>
To: "Eugene Denisov" <dea at sendmail.ru>
Cc: <rtems-users at rtems.com>
Sent: Friday, December 12, 2003 1:18 AM
Subject: Re: Problem with ATA driver on pc386
> Yes -- I am using rtems-4.6.0pre4 with pc386dx BSP
> This my systme header
> #include <bsp.h> /* for device driver prototypes */
> #ifdef RTEMS_BSP_HAS_IDE_DRIVER
> #include <rtems/ata.h> /* for ata driver prototype */
> #include <libchip/ide_ctrl.h> /* for general ide driver prototype */
> #endif
> #include <tty_drv.h>
> #include <console.h>
> #include <clockdrv.h>
> #include <timerdrv.h>
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> rtems_driver_address_table Device_drivers[] = {
>         CONSOLE_DRIVER_TABLE_ENTRY,
>         TTY1_DRIVER_TABLE_ENTRY,
>         /*TTY2_DRIVER_TABLE_ENTRY,*/
>                 MIDIPORT_1_DRIVER_TABLE_ENTRY,
>         CLOCK_DRIVER_TABLE_ENTRY,
>                 IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
>                 /* important: ATA driver must be after ide drivers */
>                 ATA_DRIVER_TABLE_ENTRY ,
> #endif
>         {NULL,NULL,NULL,NULL,NULL,NULL},
> #include <rtems/bdbuf.h>
> rtems_bdbuf_config rtems_bdbuf_configuration[] = {
>   {512,128,NULL}
> int rtems_bdbuf_configuration_size =( sizeof(rtems_bdbuf_configuration)
>                      /sizeof(rtems_bdbuf_configuration[0]));
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
> #define CONFIGURE_MICROSECONDS_PER_TICK 1000 /* 1 ms */
> #define CONFIGURE_MAXIMUM_TASKS             20
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES    20
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_EXTRA_TASK_STACKS
> (CONFIGURE_MAXIMUM_TASKS*10*RTEMS_MINIMUM_STACK_SIZE)
> Eugene Denisov wrote:
> >Hello all.
> >I trying to use ATA driver in RTEMS 4.6.0pre5 on pc386 target, this is
the
> >driver table I used to:
> >#ifdef CONFIGURE_INIT
> >        ,CLOCK_DRIVER_TABLE_ENTRY
> >        ,IDE_CONTROLLER_DRIVER_TABLE_ENTRY
> >#if 1
> >        ,ATA_DRIVER_TABLE_ENTRY
> >#endif
> >Unfortunately system hungs up when I enabling ATA driver.
> >Does anyone succesfully use ATA driver for this RTEMS build?
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
